Catalytic Converters
JDANIELL
  • 1999 FORD
This is a California car. I'm being told that it has two converters and that the 'fordward' one is bad causing a trouble code to set.
Does this make sense?
Do you
have the same problem?
Wednesday, January 11th, 2006 AT 9:03 PM
TROYMAJESTY
Yes your car is equipped with two converters one which is called a pre-cat which you should find coming off of the exhaust manifold and the other one is the main converter located closer to your muffler does this car have 2 oxygen sensors?
Wednesday, January 11th, 2006 AT 10:11 PM
JDANIELL
Thanks for the response.
Yes. One sensor is visible from the engine compartment - close to the exhaust heat shield & the other is underneath near the second cat.
Jim
Thursday, January 12th, 2006 AT 8:20 PM
Recommended Guides
