Ford 2002 Mustang
JENNIE_28
  • 2002 FORD MUSTANG
This morning as I was driving to work my car started to pull really bad like I was stalling and wouldn't go past 3000 rpm and my engine light started blinking. Also heard a knocking sound too. What is the cause of that.
Do you
have the same problem?
Tuesday, October 16th, 2007 AT 11:53 AM
FISHERMAN
Hello Jennie !
Did you continue driving the car?
Check the Fluids as soon as possible !
Water, Coolant on reservoir, Engine Oil, Transmission oil and power steering fluid.
Let us know what is the condition and levels.
We Will be here waiting for your answer.
Tuesday, October 16th, 2007 AT 12:12 PM
JENNIE_28
I had an engine misfire and did a diagnostic code p0401. I didn't continue driving I was only around the corner from my house so I turned around and got my other car. My husband will replace my spark plugs and my change my exhaust gas circulation.
Tuesday, October 16th, 2007 AT 8:27 PM
FISHERMAN
Hello !
Got scared! I thought it was a low oil engine. (Heard a knocking sound).
He Is Right.
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
could be EGR Plugged or malfunction.
Anyhow. Let us know!
Good Luck and thanks a lot for your donation!
Tuesday, October 16th, 2007 AT 8:56 PM
Recommended Guides
