95 Ford Mustang 3.8 V6 runs on 4 cylinders
VW200486
  • 1995 FORD MUSTANG
Hi I have a 95 ford mustang 3.8 6 cylynder it has a rebuilt engine in it and it wont run right.
my problem is that its only giving spark to 4 cylinders ive tryed everything to fix the problem ive changed the ignition control modual, the pcm, the coil, the cranshaft positioning sensor and nothing seems to change it, and when you pull the plug wires off to check for spark the spark is red not blue like it should be.
Do you
have the same problem?
Tuesday, February 20th, 2007 AT 12:54 PM
KIN CHAN
Don't ever pull plug wires out from a sys u r not familiar. 1 of my monkies did that on his 04 chevy truck and it kill the driver module!. In ur case. Let me think. Have u chk the compression on those 2 dead holes?. Await for ur answer --> send me a msg and we'll go from there. Is a pre OBD2 sys. No problem. How hard can that be.
Wednesday, February 21st, 2007 AT 11:57 AM
Recommended Guides
