2003 Ford Mustang pulling fault code
KEBO
  • 2003 FORD MUSTANG
Computer problem
2003 Ford Mustang V8 Two Wheel Drive Automatic
does check engine light have to be onto pull codes
Do you
have the same problem?
Wednesday, December 3rd, 2008 AT 8:14 PM
DAVE H
  • EXPERT
No. There could be codes pending without the light being set? Generally if you have a powertrain fault. Ie. Rough running the light will come on and stay on. If the fault is intermittent it may flash the light. Then stay off for a while. But the code will still be stored. The CEL doesn't stay on untill the PCM has picked up the same fault 2/3 times?
Wednesday, December 3rd, 2008 AT 8:16 PM
Recommended Guides
