Where is bank 1 of the camshaft position sensor? As your looking at the engine is it on the left of right?
Monday, January 7th, 2013 AT 7:39 PM
WRENCHTECH
MECHANIC
Here is a guide to walk you through the steps of changing the camshaft sensor and diagrams below to show you the location and instructions on both six and eight cylinder engines.
Images (Click to make bigger)
SPONSORED LINKS
Monday, January 7th, 2013 AT 7:50 PM
GPW
MEMBER
1 POST
2004 FORD MUSTANG
6 CYL
2WD
AUTOMATIC
88,000 MILES
Location of the camshaft positioning sensor on the 2004 mustang 3.9 v-6.
Friday, January 18th, 2019 AT 5:47 PM
(Merged)
2CARPRO JACK
MECHANIC
Front of engine below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
(Merged)
ZARENA
MEMBER
2004 FORD MUSTANG
3.9L
V6
2WD
AUTOMATIC
81,000 MILES
The check engine light was on in my 2004 Ford mustang. The code that came up was P0340. Which is the camshaft position sensor.
I would like to know where I can locate the the camshaft sensor so that I can install it my self. This will be my first time, so if you can give me thorough instructions as well please?
(Merged)
CATAFINA
MECHANIC
Refer to illustration:
SPONSORED LINKS
(Merged)
HMAC300
MECHANIC
Unhook electrical, remove bolt and pull sensor out. Reverse for reassembly
(Merged)
ZARENA
MEMBER
Catafina, that image doesn't look the same as my engine. On mine the belt is at the front of the car not to the side
Friday, January 18th, 2019 AT 5:48 PM
(Merged)
HMAC300
MECHANIC
Robably have a 3.8L not a 3.9L it's below ignition coil
(Merged)
HMAC300
MECHANIC
Catafina is a member not one from 2carpros he sent you a pic of a 4cyl
(Merged)
MYSTARTERKIT15
MEMBER
FORD MUSTANG
I have a 2002 mustang v6 with 89,000 miles on it. Where is the camshaft sensor located and how do I replace it?
(Merged)
MECHANIC
See below and select your engine in liter/s
(Merged)
MECHANIC
Inbox : Message
To: rasmataz
Posted: Fri Sep 21, 2007 8:32 am
Subject: CAMSHAFT SENSOR
You replied to my question about the camshaft sensor but I cant really see what you put on there. Its just kind of a blur. Could you just give me the internet site so I can see it?
Thnks.
Julie
Engine Liter
3.8L on from of engine below ignition coil
4.6 on left front of engine
SPONSORED LINKS
(Merged)
MIKEWADE420
MEMBER
1 POST
2003 FORD MUSTANG
Engine Performance problem
2003 Ford Mustang V8 Two Wheel Drive Manual
where is the cam shaft sensor located?
(Merged)
DOCFIXIT
MECHANIC
Left front side engine just below PS resivor
(Merged)
LGILLESPIE1967
MEMBER
1 POST
2002 FORD MUSTANG
134,000 MILES
The car does start hard after warmed up. The left side head sensor is obvious behind the steering pump reservoir. The right side sensor is not in the same position. Perhaps The Chilton manual Ihave does a poor job of showing the location. It also does not confirm that the right side of engine is bank A.
(Merged)
FIXITMR
MECHANIC
Your Cam Position Sensor is located on the right side of the engine if you're looking at it from the front. It is a little black thing right under the valve cover.
(Merged)
ANTHONY19
MEMBER
2006 FORD MUSTANG
V8
2WD
AUTOMATIC
58,500 MILES
Engine light came on diagnosis said camshaft sensor replaced it but my engine light is still on even when I take my battery post off it comes on again what should I do?
(Merged)
BLUELIGHTNIN6
MECHANIC
You need to have the trouble code erased using a scan tool, removing battery cable does not work on newer vehicles such as this. The code is still stored even with battery disconnected.
(Merged)
STANGINSEAN
MEMBER
1 POST
2003 FORD MUSTANG
V8
2WD
AUTOMATIC
71,000 MILES
I recently got a check engine light come on and scanned it and got the code P0340 which is Camshaft Position Sensor. So me and a buddy cleaned it and tested and ruled out the wires. So I came to the conclusion that itd have to be to the Sensor then, but I have read about the Alternator causing the problem with interference. How would I go about testing if this is the case instead of playing a guessing game and replacing the alternator & the Sensor?
(Merged)
DAVE H
MECHANIC
The interference gets in by the wiring connectors insulation not being on correctly as long as it is insulated correctly there should be no interference. Try adding a little more insulation, clean sensor, clear codes and drive vehicle around to test?
