2001 Ford Mustang M.A.F?
DUSTO1002
  • 2001 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 110,000 MILES
My car wont start with jus key turn. If I pour gas into the air filter it will start and stay running as long as I stay on the gas, a friend had said it could b the m.A.F sensor, so I changed the sensor and still have the problem, is there anyway it could be the idle control sensor? Or even a really bad exhaust leak?
the car also occasionally idled very low wen I came to stops, which is y I say it cud b the idle control sensor, it also idled very high at times too. Thanks for the advice.
Do you
have the same problem?
Saturday, November 14th, 2009 AT 5:56 PM
HERC20002003
Sounds like you need to adjust your idle up.
Monday, November 23rd, 2009 AT 10:53 PM
Recommended Guides
