1999 Ford Mustang sometimes the engine cranks but will not
NSC
  • 1999 FORD MUSTANG
  • 6 CYL
  • 85,000 MILES
Many Fords and Mercury's use security ignition keys with an "s" on the metal part of the key and an RFID chip inside. If you own a second Ford or Mercury and have two keys on your key ring the security system may periodically sense the other key (since they are close together)and not allow the engine to start. I found a hint in the owners manual and have experienced the problem several times myself.
Do you
have the same problem?
Monday, June 29th, 2009 AT 1:08 PM
BUDDYCRAIGG
  • EXPERT
Neat tip
Monday, June 29th, 2009 AT 4:01 PM
Recommended Guides
