1994 Ford Mustang Temp Gauge
NAVNIK531
  • 1994 FORD MUSTANG
  • V8
  • MANUAL
  • 125,000 MILES
Recently replaced the stock radiator and the alternator, and then performed a cooling flush and an oil change.
When the car sits at idle the temp gauge will barely make it to the N in Normal. The heat is usually on when testing this. When the engine is rev'd, the temp gauge will sometimes fluctuate very quickly all the way up past the R in Normal, and then almost as fast go back to its original position below the N. When the gauge does go up like that, the heat starts blowing harder and also feels a lot hotter than it normally does.
I have let it run for an hour or more and the temp gauge never goes past the N unless the engine is rev'd. I am unsure what might cause this, but any help would be much appreciated.
Do you
have the same problem?
Monday, June 8th, 2009 AT 11:52 PM
Replace the thermostat and see what happens.
Tuesday, June 9th, 2009 AT 9:41 AM
Recommended Guides
