Car will not start
PENN12345
  • 1994 FORD MUSTANG
  • V6
  • MANUAL
  • 20,000 MILES
When I turn the car key on only the battery light pop's up. Fuel pump wont turn on. No spark from the spark plugs. And injectors wont pulse. I have already change the computer and the (CCRM). What can be the problem?
Saturday, January 5th, 2019 AT 8:16 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
It sounds like the crankshaft angle sensor has gone out. here is a guide to help walk you through the steps and the location of the sensor for your car is in the diagram below:
This guide can help as well
Monday, January 7th, 2019 AT 12:27 PM
PENN12345
I got it stared.
I run a hot direct wire to the PCM.
I guess there was a shortage in the hot wire somewhere.
Tuesday, January 8th, 2019 AT 1:09 PM
KEN L
  • 42,883 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Wednesday, January 9th, 2019 AT 9:22 AM
94SUPERSTANG
  • 1994 FORD MUSTANG
  • V8
  • 17,000 MILES
I have a 94 gt mustang car wont start, I changed the tps, iac, eecm, ignition relay fuel pump and filter, fuel pressure reg, turns over strong but wont start if I take out the spout chip it starts but runs bad put the spout back in car dies and wont start back up, help me please.
Wednesday, January 9th, 2019 AT 9:23 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Do u have an ignition control module mounted on the distributor
I would check /change it
https://www.2carpros.com/forum/automotive_pictures/99387_mustang_1.jpg
94SUPERSTANG
I have changed the ignition control module its new as I stated in my question, like I said it will run if you pull the spout put the spout back in car dies, My ignition control relay and the spout are located on the passanger fender well under the air filter.
DISHONGH82
  • 1994 FORD MUSTANG
  • 132,000 MILES
Drivin acted like it jumped time when it died gas flored 1200 rpm engine backfired wouldnt go git it home it had burned up the cap and rotor changed it out also replaced rotor car ran fine for two blocks car will not fire at all now any suggestions
Go to this walk thru link: https://www.2carpros.com/articles/car-cranks-but-wont-start
TNT3904
If your getting no spark to coil, then cps sensor is bad, if you are getting spark
Threw coil and dist. To plugs then your cam timing has jumped.
Wednesday, January 9th, 2019 AT 9:24 AM (Merged)
MGILLARD
  • 1994 FORD MUSTANG
Engine Mechanical problem
1994 Ford Mustang 6 cyl Automatic
It will not start and the engine is not getting any fire
JAMES W.
  • 2,395 POSTS
What have you checked so far other than you have no spark?
Fuel pump running?
Fuel pressure?
Injector pulse?
Please advise.
MGILLARD
I replaced the ignition coils and checked to see if there was a spark, but there wasn't.
JAMES W.
  • 2,395 POSTS
Your going to have to check fuel pressure and injector pulse so we can narrow this down. Can you hear the fuel pump running?
MGILLARD
The car turns over but will not start. There is no spark. Its getting fuel. I dont know how to check the injector pulse.
JAMES W.
  • 2,395 POSTS
To check an ordinary test light and connect it to the terminals of any injector connector. Have someone crank the engine as you watch the test light. You're looking for the light to "blink" which indicates an injector. No blinky/no pulsey.
RITCHIE58
  • 1994 FORD MUSTANG
  • V8
  • MANUAL
  • 80,000 MILES
Hi. I have a 94 Mustang GT. I drove into a big dip along the side of the road while parking. It was a pretty hard hit. No problems right after the hit. As days passed the engine would crank but it would not fire. It could take a few minutes to fire. Then it was about 10 minutes of cranking before it would fire. Once started it would run great, no miss or anything. Now it won't fire at all. There is no spark while cranking. I changed the ICM, coil, cap and rotor. The wires and plugs are newer. There is fuel pressure. I checked connections. I have the right voltage while cranking. I can't figure out why it won't fire. There is voltage at coil while cranking. What else could be the problem. I have never had a problem with the car prior. Thanks
Inspect and test the distributor pick-up coil
RITCHIE58
If that was bad would it run ok. Once it started it ran great.
You said no spark-if the pick-up coil is defective you won't get spark-also I suggest you check the fuel pressure if its within specs-
BUTCH SHULL
  • 34 POSTS
When you say you have power at coil all the time. One side of the coil should be power the other side should flash when cranking if it does the pick up and module should be okay I believe the t/y wire at the coil should flash when tested with a test light. Also possible ccrm located in passenger front fender area under inside fender well could be going bad.
