1992 Ford Mustang Mustang wont start
JAC434
  • 1992 FORD MUSTANG
Engine Mechanical problem
1992 Ford Mustang V8 Two Wheel Drive Manual
my mustang will not start. When I turn the key to the on position the fuel pump primes but does not cut off after a few seconds. It just keeps running. Ive replaced the fuel pump fuel pressure regulator, fuel filter, and the fuel pump relay. The car does the same thing I hear the fuel pump come on when the key is in the on position but when I try to start all it does is turn over but dosent run. Ive sprayed fuel in the intake and it runs for a few seconds then so I know im getting fire. What do I need to look for now?
Do you
have the same problem?
Thursday, March 11th, 2010 AT 7:09 AM
Check if the injectors are pulsing
Thursday, March 11th, 2010 AT 8:34 AM
Recommended Guides
