1990 Ford Mustang OBD1 help
LILBROOKLYN
  • 1990 FORD MUSTANG
Electrical problem
1990 Ford Mustang V8 Two Wheel Drive Automatic
i need help with some codes and meanings code 11 code 13 code34 code19 if I could get help fixing it would be appreciated thank you 1990 5.0 mustang lx
Do you
have the same problem?
Friday, September 3rd, 2010 AT 12:12 AM
  • EXPERT
Hi there,
Here is a list of all the flash codes, keep it for future reference, what I would do is clear the codes and see what re sets, as I feel some may be old codes, often when you get 11(system pass) with other codes this is the case.
Mark (mhpautos)
Ford
11 System "pass"
12 Unable to control RPM to Self Test upper limit band.
13 Unable to control RPM to Self Test lower limit band.
14 PIP circuit failure.
18 No tach.
19 Failure of EEC power supply.
21 ECT out of range.
22 MAP out of range.
23 TPS out of range.
29 Insufficient input from Vehicle Speed Sensor.
31 PFE circuit is below minimum.
32 EGR valve not seated.
33 EVP not closing properly.
34 No EGR flow.
35 PFE circuit is above maximum voltage.
39 AXOD converter bypass not applying correctly.
41 HEGO sensor circuit indicates system lean (Right HEGO).
42 HEGO sensor circuit indicates system rich (Right HEGO).
51 ECT sensor input too high.
52 Power steering pressure switch is open.
53 TPS input too high.
54 ACT (VAT) input too high.
57 AXOD Neutral Pressure Switch open.
59 Transhydraulic switch (THS 3/4) failed in open position.
61 ECT input too low.
63 TPS input too low.
64 ACT (VAT) input too low.
67 AXOD Neutral Pressure Switch closed.
68 AXOD Transmission Temperature Switch open.
69 Transhydraulic switch (THS 3/2) failed.
70 EEC-IV data transmission circuit failed.
71 Cluster Control Assembly circuit failed.
72 Message Center Control Assembly circuit failed.
74 Brake on/off circuit failed.
79 A/C on during Self Test.
83 High speed Electro Drive Fan circuit failure.
84 EGR Vacuum Regulator circuit failure.
85 Canister purge (CANP) circuit failure.
87 Fuel pump primary circuit fault.
88 Electro Drive Fan circuit failure.
89 AXOD Lock Up Solenoid circuit failure.
91 HEGO sensor circuit indicates system lean (Left HEGO).
92 HEGO sensor circuit indicates system Rich (Left HEGO).
95 Fuel pump secondary circuit failure.
96 Fuel pump secondary circuit failure.
Friday, September 3rd, 2010 AT 1:56 AM
Recommended Guides
