1990 Ford Mustang
RICHARD OTTE
  • 1990 FORD MUSTANG
Engine Mechanical problem
1990 Ford Mustang V8 Manual
my car leaks oil not sure from where just see oil underneath it and when it gets warm the oil pressure goes down what do you think it is?
Do you
have the same problem?
Wednesday, August 6th, 2008 AT 3:53 PM
MUSTANG87
Where is the oil under car on floor?Could be the oil pan gasket or the main seal. Also check behind the valve covers maybe leaking from there and dripping down the back of motor to floor. Check the oil filter is it nice and tight?Is it leaking from there?Possible bad rubber gasket on oil filter >?Maybe was intalled to tight and they broke the gasket?Oil pressure switch sender>?Good luck
Wednesday, August 6th, 2008 AT 4:55 PM
Recommended Guides
