Focus 2002, high RPM no shifting into overdrive on automatic
SBUDCO
  • 2002 FORD FOCUS
I have a problem where the engine RPMs would jump high and the car wouldn't accelerate. Looks like it's shifting fine first 3 gears, and won't go to 4th or overdrive. RPM goes very high, but the car won't shift the gear.
If I drive with overdrive off all shifting is fine, but I can't really go over 80km/h or so.
I have 145 000 km and not sure if it's a simple problem or something more complex.
One of the tech described problem as "shift solenoid A failure" please help.
Ford Focus SE ztec engine.
Do you
have the same problem?
Wednesday, February 22nd, 2006 AT 6:00 PM
TIML
Have you tried scanning for codes. Might be a good start. At least it gies you a starting point.
Saturday, February 25th, 2006 AT 3:05 PM
