Blower speed problem
BOWMAN14
  • 2002 FORD FOCUS
  • 2.0L
  • 4 CYL
  • FWD
  • 225,000 MILES
My blower doesn't work on settings 1-3, but works only on 4. To add to this the AC lights turn on on level 1-3. Yes the compressor does cycle. When I put the blower on 4 the AC shuts off. Kinda puzzled about this, what are your thoughts? What should I do?
Friday, April 10th, 2015 AT 8:58 AM
HMAC300
  • 48,601 POSTS
Check tosee if power is going to resistor and then to blower for speeds 1-3 it's next to blower motor. Check wide open throttle relay and power hold relay under hood for a/c problem if not that then have a pro look at it it may be a control unit problem.
Friday, April 10th, 2015 AT 9:31 AM
INGEBORG
  • 2001 FORD FOCUS
  • 4 CYL
  • FWD
  • MANUAL
  • 135,000 MILES
My fan only works on setting 4, this is the 3rd time this has happened both times before it cost me almost $500 in repairs and I don't think that it should. A friend suggested that it is a simple case of replacing the resistor and that part is approx $40. Can you tell me if that is the most likely cause and how easy is it to change the resistor?
Thursday, January 14th, 2021 AT 8:52 AM (Merged)
SAWMASTER88
  • 38 POSTS
I believe that you friend has hit it right on the head. It sounds like the blower motor resistor has failed. On this car the blower motor is behind the glove box on the passenger side. To access it remove the screws (I believe there is 4) along the bottom of the glove box and take the glove box out. Once it is out you should see the blower motor housing. There will be 3 bolts holding the blower motor in from the bottom. You should find the resistor in the same general area as the blower motor. Hope this helps. Good Luck.
GCHILD73
  • 2000 FORD FOCUS
Heater problem
2000 Ford Focus 4 cyl Front Wheel Drive Manual
The heater/ventilation system seems to work on settings 1, 2, & 3, but when I switch it to setting 4, it does nothing. Also when I switch to setting 4, the overhead dome light seems to flicker. This car has no A/C. I have replaced the blower motor resistor, as it would have been a cheap easy fix. If anyone has a good idea to start with, I would be very appreciative.
Thursday, January 14th, 2021 AT 8:53 AM (Merged)
DLOBI
  • 125 POSTS
The blower motor resistor may have still been good. A lot of them default to the highest setting if they go bad. It may be that the switch itself is bad and not making a contact anymore at the #4 setting. Sounds like you are handy, I'd pull the center of the lower dash apart where the heater/blower speed switch is and swap that out for a known good one.
JDL
  • 16,098 POSTS
Voltage to the blower motor is hot all the time, key on. On and off, different speeds are controled on the ground circuit. Your speed control switch is part of ground circuit.
REPOKING
  • 2000 FORD FOCUS
Heater problem
2000 Ford Focus 4 cyl Front Wheel Drive Automatic 112k miles
Have a 2000 ZX3. Heater motor only blows on low speed. Just replaced the resistor block, even though when those are bad it usually only blows "hi". It's getting really cold up here in the North country, and my girlfriend is in need of heat/defrost. Any help would be appreciated.
Thanks!
  • 108,179 POSTS
Hi:
Have you checked the switch itself? If the motor is good and you replaced the resister, that would be my next guess. See if you are getting power on all settings. (NOTE: If you put the switch on med or hi does it still run on low?)
