I have a 97 Ford f350 7.3L Diesel with 165,000miles on it. If you pump the brake pedal, half a dozen times the brake light will come on. The brake fluid is ok, I tested the booster and that seems to be ok. Any suggestions on why the light will come on?
SPONSORED LINKS
Do you
have the same problem?
Sunday, February 26th, 2006 AT 2:45 PM
