2004 Ford F350 f 350 6.0 diesel
RONSON36
  • 2004 FORD F-350
  • V8
  • 4WD
  • 100,000 MILES
Starts good runs sometimes 10-20 min and dies also loses power and tries to die when brake is depressed? Thank you for the help
Do you
have the same problem?
Monday, January 4th, 2010 AT 10:08 AM
JACK42
Any check engine light? If so have it scanned to see what codes are stored in the PCM. The brakes are run off hydraulic boost instead of vacuum on heavy duty trucks, but im not sure if yours falls into that category, so im not sure of the relationship between those items and the stalling. Does it die if it is in neautral? Or does it have to be in drive to stall?
Wednesday, January 20th, 2010 AT 4:33 PM
Recommended Guides
