1988 Ford F350 Fuel Pump / not starting
FIREBOY951
  • 1988 FORD F-350
  • V8
  • 4WD
  • 132,000 MILES
I have an 88 F350 with a 460. It started running a little rough and then died. It will not start. I have fire to the plugs. I changed the fuel filter, it was past due. I turn the key on and hear both pumps run. The pump in the tank is making a gurgling sound. They do not shut off. I thought the pumps should shut off when pressure was built up. I pushed the Schedar valve on the fuel rail and fuel sprays out. Is it possible to over pressurize the fuel system? I am out of ideas. Please help!
Do you
have the same problem?
Saturday, August 15th, 2009 AT 7:17 PM
BHAV146
Any luck I am having the same issue.
Saturday, August 29th, 2009 AT 2:36 PM
Recommended Guides
