Could this be?
KOONTZ5233
  • FORD F-250
1996 Ford Mustang no start in park only it will start in nuetral, shifting gears is tight in the auto trans, could the cable be the reason for the no start because the nuetral safety switch seems to be working according to snap-on scanner mt2500.
Do you
have the same problem?
Thursday, July 27th, 2006 AT 2:46 PM
TAURUSWHEEL
Check the operation of the mlps, multilever position sensor otherwise known as the neutral safety switch, known troublemaker even though appears to be right. If you have access to a manual, there is a procedure to make sure it is calibrated correctly which consists of lining up a couple of marks, then retightening the bolts which secure it. Why would the shift cable suddenly tighten up?
Thursday, July 27th, 2006 AT 7:50 PM
Recommended Guides
