1994 Ford F-250 FUEL PUMP
MARC JACOBS
  • 1994 FORD F-250
  • V8
  • 4WD
  • 130,000 MILES
I GOT A 94 F250 I BOUGHT NOT RUNNING FIGURED OUT IT WAS THE FUEL PUMPS, I REPLACED BOTH PUMPS AND THE TRUCK STARTED AND RAN GREAT. BUT DISCOVERED THE TRANS WAS BAD. SO THE TRUCK HAS BEEN SITING FOR 4 MONTHS. WELL NOW I WAS GOING TO TAKE TO TRANS SHOP BUT THE TRUCK WONT START, NO FUEL PUMP PRESSURE, IVE CHECKED FUSES AND THE INERTA SWITCH ALL IS OK WHAT ELSE SHOULD I CHECK FOR?
Do you
have the same problem?
Sunday, February 15th, 2009 AT 3:43 PM
Find the fuel pump relay and test it
Sunday, February 15th, 2009 AT 3:57 PM
Recommended Guides
