Transmission shifts hard into OD
JASONMICHEL
  • FORD F-150
1992 F150 super 4x4 5.8L, when I accelerate up and past 55 it don't go into OD unless I let off gas, and then when it does it goes in hard, I currently have an issue with the shift cable, but I wouldn't think those are connected? Any idea? Is there an easy way to tell if it is an AOD or E4OD. Thanks in advance
Do you
have the same problem?
Monday, November 12th, 2007 AT 1:00 PM
IMNOTLOKIN
I can't give real good advice for this, but here is what I found. Has the tranny oil been changed lately? My shifts hard also. I noticed the overdrive clutch is slipping. The cable should be taken off at the trans and check if it has a free pin fit when the shift lever is moved into each gear. I start at neutral. A basic repair manual can show a good photo.
Hope this helps.
Wednesday, November 14th, 2007 AT 11:49 PM
Recommended Guides
