G.E.M.
POPAWANGER
  • FORD F-150
98 Ford F-150 114,000mi. I have just recently bought this truck with one problem; the dome light did not work. I have been trying to fix this problem, but all I think I have done is worsen the situation. The power windows, the door lights and the cargo light does not work. There are some instances where all of these lights and windows work fine. These instances are usually during start up after a cold night. Also, if the lighting and windows do decide to work, it is all or nothing. All the windows and lighting works perfectly. I have only came down to the G.E.M. Causing this problem.
Do you
have the same problem?
Tuesday, January 17th, 2006 AT 4:50 PM
JACK42
You and almost everyone else that owns a Ford
Wednesday, January 18th, 2006 AT 4:55 PM
Recommended Guides
