Clutch pedal position switch removal
KEITH22
  • FORD F-150
How do you remove the clutch pedal position switch on a 1998 Ford F150 2 wh drive v6 standard transmission?
Also, how do you remove the clutch master cylinder?
Your help is greatly appreciated.
Do you
have the same problem?
Saturday, January 6th, 2007 AT 12:57 PM
CARUNDELL
Hey keith,
The clutch switch "should" be "clipped" to the clutch pedal and the master should bolt thru the firewall.
Chris
Saturday, January 6th, 2007 AT 2:16 PM
Recommended Guides
