99 F-150 Brakes
WILLARD
  • 1999 FORD F-150
I noticed the right front wheel on my f150 is hot after driving, the other 3 are not like that. I had the brakes checked out and the Ford dealer said they are ok. Is it normal for one wheel to heat up and the others not?
I jacked the truck up today and its hard to spin the tire even with the truck not running, not sure if that means anything just thought I should add it.
Well I bought a new caliper today and installed it, everything is fine now.
thanks for the tip Pud
Do you
have the same problem?
Friday, February 17th, 2006 AT 9:46 PM
LOVESCARS
May be a caliper on it's way out
Saturday, February 18th, 2006 AT 7:31 AM
Recommended Guides
