96 Automatic Gear Shifter Removal
BSHEPARD
  • 1996 FORD F-150
I have a 1996 F150 with an automatic transmission. I need to replace the shifter on the column because the end that has the overdrive button on it broke. I have the new selector, but cannot figure out how to get the small pin out of the base. Help!
Do you
have the same problem?
Tuesday, September 4th, 2007 AT 1:43 PM
MERLIN2021
  • EXPERT
You remove the pin with a small punch.
Tuesday, September 4th, 2007 AT 1:55 PM
Recommended Guides
