2006 Ford F-150 No Codes
BANDDAD
  • 2006 FORD F-150
  • 6 CYL
  • 126,477 MILES
After you start the truck, when you shut it off, you have to wait about ten second for the check engine light to come back on. Will not pass inspection.
Do you
have the same problem?
Tuesday, July 27th, 2010 AT 7:34 AM
  • EXPERT
I'm not sure I understand. Is the light off when the engine is running?
Tuesday, July 27th, 2010 AT 10:52 PM
BANDDAD
The check engine light go off when it running.
What I have found out is that this will happen after you rest the the computer or unhook the battery.
Until the computer goes through all it test.
Drove the truck all day yesterday and have two more incomplete, hopeful it will clear today.
Thank You
Wednesday, July 28th, 2010 AT 5:47 AM
  • EXPERT
Have you checked for codes?
Wednesday, July 28th, 2010 AT 10:20 PM
Recommended Guides
