2006 Ford F-150 Lack of Power when taking off
BPENDINO
  • 2006 FORD F-150
  • V8
  • 90,000 MILES
I have a 4.6L V8 F-150 that seems to be short on power when taking off. I plan to clean the MAF sensor tomorrow and see if that makes any improvement.
When I put the K&N Air filter in place it seemed to improve a bit, which makes me think it could be an Air flow issue. I don't seem to see a problem with Air flow, but I'm not certian as to how dirty the MAF sensor is.
Any other suggestions to improve performance?
Do you
have the same problem?
Sunday, November 15th, 2009 AT 2:04 AM
SERVICE WRITER
  • EXPERT
90,000 miles. Have you taken a look at the spark plugs? Has there been any carbon cleaning procedures done?
IF you have a fuel pressure gauge, you can run it up to the windsheild to monitor it for a loss of pressure at that time.
Typically you would have the cel light up if the MAF was a problem, but it certainly can hurt to clean it out with electrical cleaner. I assume no CEL is lit?
Sunday, November 15th, 2009 AT 2:49 AM
BPENDINO
Yes, as to the plugs, I suspected the same so I actually I just replaced the plugs 2 months ago. They are brand new Bosh Platinum +2 plugs. This seemed to help the situation some, but did not eliminate the problem.
Aside from running LUCUS through the system, I have not done any carbon build-up cleaning. I was considering running some seafoam through the system. (A friend swears by the stuff)
No CEL is lit. However, when I had similar problems with my Maxima, it ended up being the MAF, and it never lit either. That MAF ended up getting replaced, and it was a Night/Day difference.
I do not have a fuel pressure guage available. Being a shadetree mechanic, how difficult is it to hook up and use one of those?
Thanks for the reply and suggestion.
Monday, November 16th, 2009 AT 9:49 AM
SERVICE WRITER
  • EXPERT
Safoam is good and do suggest it.
I would never use bosch plugs from experience.
The fuel gauge plugs into the fuel rail at the schrader valve. Look under "how to service and repair " section I believe.
Monday, November 16th, 2009 AT 10:38 AM
Recommended Guides
