Timing chain and cover replacement?
JEREMY SALING
  • 2012 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 140,000 MILES
Lost my A/C on the way home from work. Popped the hood and found a big hole in my timing chain cover along with a broken belt. Don’t know what part number to replace the timing chain cover and timing chain?
Wednesday, April 24th, 2019 AT 5:24 PM
SCGRANTURISMO
  • 4,897 POSTS
Ouch! I have had similar things like that happen to me before. One time I got home from a friend's house, parked my Chevrolet Cobalt in the driveway, woke up the next morning and was going to run to the grocery store for some breakfast, and the vehicle would not start. Come to find out that somehow over night a timing chain tensioner had given way and when I went to start it, it jumped time. It has an interference engine it, and, to make a long story short, the junkyard gave me $100.00 for it, bent valves and all.
Anyways, I sympathize with you. I have included the information you requested in the diagrams down below. Please, don't hesitate if you have any other vehicle related questions. It's what we do. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks, Alex
Wednesday, April 24th, 2019 AT 7:29 PM
GARYROADEN
  • 2005 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 72,000 MILES
Doing timing chain replacement including guides and tension-er's. The new left side (driver side) tension-er does not have the small drilled port in center of plunger that is actuated by the HP oil system. Old one removed does have this opening. The new right side tension-er does have this opening. Assumed this was intended for oil flow or return. Checked 5 national auto supply chains and 2 Ford OEM dealers and none of the left side replacement tension-er have this opening in center of the plunger. Question, did Ford do a modification for this part and will the lack of this opening in the center of tension-er plunger effect performance?
Saturday, August 22nd, 2020 AT 11:11 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,878 POSTS
Ford did do a modification to the tension-er which will not affect the performance, you are good to go.
Cheers, Ken
RUSTYBGOOD
  • 2005 FORD F-150
  • V8
  • 4WD
  • 99,000 MILES
When replacing the tensioners for the timing chain, at the mileage of 99,000, should the chain be replaced? Are there any other parts during this work which is being done in conjunction with cam shaft senor replacement that I should address?
BLACKOP555
  • 10,371 POSTS
Since your going to be messing with the chain, check the wear and replace it if it is 50% of the allowable or if its less of the allowable slack.
If I were you I would just replace it no matter how worn due to the fact that it takes time to measure slack, and while you have it off why not replace the chain.
Just check the wear and replace as needed, you problably wont have to replace it but I would.
LUCKIECOWGIRL
  • 14 POSTS
  • 2005 FORD F-150
  • V8
  • 67,000 MILES
I'm hoping you can help me, My original problem was a very loud ticking in my truck I found it to be loose timing chain. I replaced the tensioner and arm and it resolved the loud ticking now I know this sounds stupid but it has a mild tapping sound now- almost as if you can hear through the oil resevoiur the chain hitting the arm i've checked the timing and it seems to be right on. I'm just completly stumped at this point, if you have any ideas as to what could possibly be preventing the chain from tightening, I would be ever so greatful thank you if advance for your help in resolving this for me
STUMPPED!
  • 31,938 POSTS
HI there, did you check the chain for stretch and the condition of the teeth on the crank & cam?
Mark (mhpautos)
LUCKIECOWGIRL
  • 14 POSTS
Yes sir I did check these and all seems fine. Any other ideas?I'm lost!
  • 31,938 POSTS
OK,
I will have to go get a manual and have a look at the system I will re post my thoughts a bit later.
Mark.
Saturday, August 22nd, 2020 AT 11:12 AM (Merged)
HOTROD1969
  • 2004 FORD F-150
Engine Mechanical problem
2004 Ford F150 V8 Four Wheel Drive Automatic
I just did a timing chain, guide rails, and tensioners on my f150 5.4 lariot 2004. The front engine noise was a very distinct rattle at initial start up it is still there until the oil pressure builds then the rattle sound goes away. The tensioners do not seem to be holding oil pressure after the engine is shut off, they seem to be bleeding off, it takes about 20 min. Of sitting. Iis there a check valve or a bleedback valve that is faulty that could be causing the tensioner to bleed off its pressure. The old tensioners were spongy when I removed them, I don't think the new ones are performing any different.
MJR346
  • 132 POSTS
There are revised cam phasers for noise, as well as recommendations to pull the front cam cap and inspect oil feed line
also make sure you are using 5w20 oil and thicker oil can cause noise
DAVY HUNT
  • 2003 FORD F-150
  • 4.6L
  • V8
  • 210,000 MILES
I have a 2003 f-150 lariat supercrew with the 4.6l triton. Long story short a lot of water in oil due to warped head. Had head resurfaced and shop took off the cam. The installed the cam back on the head when done. I 0ut the motor back together. Crank but no start symptom. I figured it's 180 out on timing so I tore it back apart and upon removing the timing cover and chain the passenger side cam/phaser turned. I tried to turn it and I get about 20 degrees either way and no more. I'm suspecting a valve is hitting on a piston. Did the same thing with timing chains on and turning crank. Goes so far then sudden halt. Can I take the cam off and reposition it without having to tear the whole damn thing back apart? And if so can someone please give me a step by step on doing so. I cannot afford a shop or mobile mechanic so I'm having to do this the at home in my spare time after. Need to get this thing right and running as it's only vehicle and I have a family that depends o this p.O.S. Running.
Saturday, August 22nd, 2020 AT 11:13 AM (Merged)
  • 52,797 POSTS
The fact that you cranked it out of time concerns me as the valves may be bent. When you get timing back, do a compression test before starting.
I attached a picture of the timing marks for you to review
DAVY HUNT
Will definitely do compression test but I know the valves and piston didn't hit when I tried cranking it as I turned the motor by hand probably 100 times before trying to start just to check that everything was smooth. It did this upon tearing the front end back down and removal of timing chains. Ohc must have been under spring pressure in turn and rotated when I removed the chains. Tried to spin it back into place but sixes after about 20 degrees of turn in either direction
TGARY
  • 2000 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 250,000 MILES
Is it a good idea to change the timing chains?
SATURNTECH9
  • 30,870 POSTS
Are the t8ming chains making any noise?As far as timing chains go there really isn't a maintenance aspect to replace them like a timing belt at a certain mileage.
DONPEPE
  • 2002 FORD F-150
  • V8
  • 4WD
  • 60,000 MILES
I like to know how the time chains how's
please.
They have a sprocket the saids front I woender if goes out to the engine or into the engine.
Thank you
Saturday, August 22nd, 2020 AT 11:15 AM (Merged)
DAVE H
  • 13,383 POSTS
This is a complex operation and not for the novice ??
Timing Drive Components-Windsor Engine
Special Tool(s)
Fig. 274: Identifying Special Tools
Courtesy of FORD MOTOR CO.
Materials
Fig. 275: Material Specifications
Removal
CAUTION:Since the engine is not free-wheeling, the timing procedures must be followed exactly or piston and valve damage can occur.
Remove the engine front cover. Refer to ENGINE FRONT COVER .
Remove the crankshaft sensor ring from the crankshaft.
Fig. 276: Removing Crankshaft Sensor Ring From Crankshaft
CAUTION:Unless otherwise instructed, at no time when the timing chains are removed and the cylinder heads are installed is the crankshaft or camshaft to be rotated. Severe piston and valve damage will occur.
Fig. 277: Positioning Crankshaft
Position the crankshaft with the keyway at the 12 o'clock position.
Install and fully tighten the special tools on both camshafts.
Fig. 278: Installing Fully Tighten Special Tools On Both Camshafts
Remove the timing chain tensioning system from both timing chains.
Remove the bolts.
Remove the timing chain tensioners.
Remove the timing chain tensioner arms.
Fig. 279: Removing Timing Chain Tensioning System From Both Timing Chains
Fig. 280: Removing RH And LH Timing Chains And Crankshaft Sprocket
CAUTION:Unless otherwise instructed, at no time when the timing chains are removed and the cylinders heads are installed is the crankshaft or camshaft to be rotated. Severe piston and valve damage will occur.
Remove the RH and LH timing chains and the crankshaft sprocket.
Remove the RH timing chain from the camshaft sprocket.
Remove the RH timing chain and from the crankshaft sprocket.
Remove the LH timing chain from the camshaft sprocket.
Remove the LH timing chain and crankshaft sprocket.
Remove both timing chain guides.
Remove the bolts.
Fig. 281: Removing Timing Chain Guides
Installation
CAUTION:Timing chain procedures must be followed exactly or damage to valves and pistons will result.
Fig. 282: Compressing Tensioner Plunger, Using A Vise
Compress the tensioner plunger, using a vise.
Install a retaining clip on the tensioner to hold the plunger in during installation.
Fig. 283: Installing Retaining Clip On Tensioner To Hold Plunger In During Installation
Remove the tensioner from the vise.
If the copper links are not visible, mark two links on one end and one link on the other end, and use as timing marks.
Fig. 284: Identifying Timing Marks On Timing Chain
Fig. 285: Installing Timing Chain Guides
Install the timing chain guides.
CAUTION:Do not turn the engine over with the camshaft positioning tool or damage to the camshaft sprocket or the bolt can occur.
Fig. 286: Installing Camshaft Positioning Tool
Fig. 287: Positioning Camshaft
Install the Camshaft Positioning Tool.
NOTE:Slightly loosen the camshaft holding tools to allow slight camshaft movement.
Pre-position the camshafts.
Rotate the LH camshaft with the Camshaft Positioning Tool until the timing mark is approximately at 12 o'clock.
Rotate the RH camshaft with the Camshaft Positioning Tool until the timing mark is approximately at 11 o'clock.
Tighten the Camshaft Holding Tools to maintain camshaft pre-positioning.
CAUTION:Rotate the crankshaft counterclockwise only. Do not rotate past position shown or severe piston and valve damage can occur.
NOTE:The number one cylinder is at top dead center (TDC) when the stud on the engine block fits into the slot in the handle of the special tool.
Fig. 288: Rotating Crankshaft Counterclockwise
Position the crankshaft so the number one cylinder is at TDC with the special tool.
Remove the Crankshaft Holding Tool.
Install the crankshaft sprocket, make sure the flange faces forward.
Fig. 289: Identifying Direction Of Flange For Installing Crankshaft Sprocket
Position the lower end of the LH (inner) timing chain on the crankshaft sprocket, aligning the timing mark on the outer flange of the crankshaft sprocket with the single copper (marked) link on the chain.
Fig. 290: Aligning Timing Mark On Outer Flange Of Crankshaft Sprocket With Single Copper (Marked) Link On Chain
NOTE:Make sure the upper half of the timing chain is below the tensioner arm dowel.
NOTE:If necessary, use the Camshaft Positioning Tool to adjust the camshaft sprocket slightly to obtain timing mark alignment.
Fig. 291: Positioning Timing Chain On Camshaft Sprocket With Camshaft Sprocket Timing Mark Positioned Between Copper (Marked) Chain Links
Position the timing chain on the camshaft sprocket with the camshaft sprocket timing mark positioned between the two copper (marked) chain links.
NOTE:The LH timing chain tensioner arm has a bump near the dowel hole, for identification.
Fig. 292: Identifying Tightening Torque Of LH Timing Chain Tensioner Bolts
Position the LH timing chain tensioner arm on the dowel pin and install the LH timing chain tensioner.
Remove the retaining clip from the LH timing chain tensioner.
Fig. 293: Removing Retaining Clip From LH Timing Chain Tensioner
NOTE:The lower half of the timing chain must be positioned above the tensioner arm dowel.
Fig. 294: Aligning Timing Mark On Sprocket With Single Copper (Marked) Link On Timing Chain
Position the lower end of the RH (outer) timing chain on the crankshaft sprocket, aligning the timing mark on the sprocket with the single copper (marked) link on the timing chain.
Fig. 295: Identifying Position Of Camshaft Sprocket Timing Mark
Position the RH timing chain on the camshaft sprocket. Make sure the camshaft sprocket timing mark is positioned between the two copper (marked) chain links.
Position the RH timing chain tensioner arm on the dowel pin and install the RH timing chain tensioner.
Fig. 296: Identifying Tightening Torque Of RH Timing Chain Tensioner Bolts
Remove the retaining clip from the RH timing chain tensioner.
Fig. 297: Removing Retaining Clip From RH Timing Chain Tensioner
As a post-check, verify correct alignment of all timing marks.
Fig. 298: Verifying Correct Alignment Of Timing Marks
Remove the special tool.
Fig. 299: Removing Special Tool
Position the crankshaft sensor ring on the crankshaft.
Fig. 300: Positioning Crankshaft Sensor Ring On Crankshaft
Install the engine front cover. Refer to ENGINE FRONT COVER .
https://www.2carpros.com/forum/automotive_pictures/266999_f150_1.jpg
