HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transmission
Reverse
2004 Ford F-150 Vibration when reverse, low speeds and after
WILLHARR
MEMBER
2004 FORD F-150
Braking, is sort of when its most noticable, what could it be? Feel in steering wheel and pedals
Do you
have the same problem?
Thursday, January 25th, 2007 AT 9:39 PM
BLACKOP555
EXPERT
Your rotors may need to be reground since you say it happens on braking and when driving.
SPONSORED LINKS
Saturday, January 5th, 2008 AT 8:50 PM
Please
login
or
register
to post a reply.
Related Transmission Reverse Content
I Lost Reverse?
Have A F150 With 44k Mileage That Has Run Flawlessly And Transmission Worked Nicely Thur These Mileage. Pulled It In The Other Day To Change...
Asked by
parkerguns
2004
FORD F-150
No Reverse - 2002 F150 Supercrew
My 2002 F150 Supercrew V8 W/auto Transmission And 97000 Miles Will Not Go Into Reverse. The Problem Started When The Overdrive Light On The...
Asked by
cherylsue79
2002
FORD F-150
Transmission Not Engaging In Drive Or Reverse When...
I Just Completed An Engine Replacement In My '97 F150, 4.6 V8, 2wd Truck. I Did Not Notice Any Torque Converter Slippage, And No Major...
Asked by
mdacrunge
1997
FORD F-150
F150 Passenger Front Wheel Binds Real Bad In Reverse...
In 2wd With Steering Wheel Straight Or Turned, The F150 Binds Real Bad While In Reverse. No Issues Going Fwd. Jacked Up The Front And Its...
Asked by
haroldkumar
1 IMAGE
2005
FORD F-150
Transmission Works In Reverse But Not In Drive
Truck Works In Reverse, But When It Is Shifted Into Drive It Will Not Move Forward. Could It Be The Transmission Position Sensor Causing...
Asked by
Kenneth boatman
2006
FORD F-150
VIEW MORE
Online car repair manuals
