Map light bulb replace
AALEXANDER
  • 2007 FORD F-150
  • 118,000 MILES
I need to replace a bulb in one of the map lights in the overhead console and I cannot figure out how to get to the bulb.
Thanks. The bulb cover is also the switch. I was afraid that I might break something
Saturday, March 30th, 2013 AT 1:16 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
Hey AALEXANDER,
It is plastic so it will give a little, here is a video that shows how to replace the map light bulb, watch it and get back to us on how it goes.
These are usually pretty straightforward when removing the plastic/covers. Use a flat head screwdriver or something similar to pry the cover off. If you see any attached screws on the light for the cover be sure to remove them before trying to pop it off. You may have to remove surrounding plastic but it shouldn't be too difficult.
http://www.youtube.com/watch?v=LCefC-6H2us
Best, Ken
Thursday, January 5th, 2017 AT 9:56 AM
ALANFISK
  • 2004 FORD F-150
  • V8
  • 4WD
  • 18,700 MILES
Interior problem
2004 Ford F150 V8 Four Wheel Drive Automatic 187, 00 miles
HOW DO I GET TO THE BULB TO REPLACE IT?
Thursday, January 5th, 2017 AT 9:57 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Usually the lens will pop off using a blunt edge tool, have the light OFF when you put the new bulb in, they get hot fast!
BAKEDUDE
  • 1998 FORD EXPEDITION
  • 64,000 MILES
Trying to remove map light bulb but I can't turn the socket to remove the socket/bulb assembly. It's feels like it's locked in to the assembly. How do I get the socket/bulb out without breaking the socket?
HMAC300
  • 48,601 POSTS
Try squeezing cover over bulb to remove we dont' have any diagrams of this to show you
