2004 Ford F-150 O2 sencer
WHYNOT
  • 2004 FORD F-150
Electrical problem
2004 Ford F150 V8 Two Wheel Drive Automatic
how long can you drive your truck with the O2 sencer bad?
Do you
have the same problem?
Sunday, December 6th, 2009 AT 8:42 PM
  • EXPERT
Actually, based on how bad it is will make a difference. The performance and efficiency will decline. Also, it can cause problems to other parts such as the catylatic converter if it is running too rich. If you can, I would recommend replacement. It is easy to do and the part should be around 75 bucks.
Monday, December 7th, 2009 AT 10:33 AM
Recommended Guides
