2004 Ford F-150 Check Charging System light
EVANSMD3
  • 2004 FORD F-150
  • V8
  • 4WD
  • 59,000 MILES
I replaced the battery in October because the truck was starting a little sluggishly. There were no warning lights but it was troubling me so the battery replacement folks (Walmart) put a tester on it, said the battery was bad and that there was a "strange" signal from the alternator but that they would check it out. They replaced the battery and said that everything was straight. Now, two plus months later, the check charging system light is coming on at stop lights and such but turning off when I hit the gas and during regular driving. Any ideas? Thanks for any help.
Do you
have the same problem?
Friday, December 26th, 2008 AT 4:45 PM
Get the alternator load tested then comeback
Friday, December 26th, 2008 AT 5:19 PM
Recommended Guides
