2004 Ford F-150 Can not get it out of park.
RONNIEN50
  • 2004 FORD F-150
  • V8
  • 89,975 MILES
I came home and put my truck into park. I went back out to move my truck and it would not start and made a funny clicking sound from the dash. It sounded like the blinkers were activated and the gauges proceeded to move from right to left with the clicking sound once they were all the way back it would pulse. If I turned on the lights or depressed the brakes it would stop? I have checked fuses they are all good. The steering wheel will only lock if I turn to the right. I am currently recharging the battery to see if thast is causing the problem. Still cannot get the shifter out of park.
Do you
have the same problem?
Sunday, June 28th, 2009 AT 3:03 PM
You probably have a problem with the shift interlock system
Sunday, June 28th, 2009 AT 4:09 PM
RONNIEN50
I tested the battery and found it had a bad cell. Replaced the Battery and the problem went away. Nice Patch had one in Korea
Sunday, June 28th, 2009 AT 4:16 PM
RONNIEN50
Western corridor 3rd brigade 2ID 7Cav Camp Gary Owens 1975
Sunday, June 28th, 2009 AT 4:20 PM
Recommended Guides
