2004 F-150 4WD/engine dies when I shift into reverse
MIKEBR
  • 2004 FORD F-150
I have a 2004 f-150 4wd with the 4.6 v-8, also has the tow package. When I start the engine, it seems to idle fine and there is no check engine light on, but when I shift into reverse the engine dies. Do you believe it is a transmission problem or something else
Do you
have the same problem?
Saturday, November 10th, 2007 AT 2:12 PM
FORDFAN
It does sound like a bad seal in the tranny
Sunday, November 11th, 2007 AT 4:06 PM
Recommended Guides
