2003 Ford F-150 Truck will turn over but will not start.
SESSIONS
  • 2003 FORD F-150
  • V8
  • 148,000 MILES
I have a 2003 Ford F150 Supercrew that was running fine. I drove it to the store and back with NO PROBLEMS. Now it will only turn over the tackometer doesnt even move when I turn it over. I have checked Fuses, replaced both Crankshaft sensor and Camshaft sensor. I have also replaced fuelpump and filter, the timming belt is fine and the truck does get a spark. What am I missing?
updated 2/21/10
As stated all fuses and relays have been checked or changed. The only code that will come up is for the o2 sensors. The VPDS will be the next thing that I will change.
Thanks,
David
Do you
have the same problem?
Friday, April 16th, 2010 AT 4:19 PM
BMRFIXIT
  • EXPERT
Turn key on, do you have check engine light on, you should if not check fuses relays and wiring
check for codes
Friday, April 16th, 2010 AT 4:49 PM
BMRFIXIT
  • EXPERT
With key on do you have check engine light on?
Wednesday, April 21st, 2010 AT 7:45 PM
