2003 Ford F-150 Truck Will Not Start
PATUS1
  • 2003 FORD F-150
Electrical problem
2003 Ford F150 V8 Two Wheel Drive Automatic
when I try to start the truck it will just click. Lights and other accessories seem to be working fine. Can start truck by jumping the solenoid. Fuse F21, 15 amp, blows every time I try to start the truck. Any suggestions as to what might be causing this? Thank you.
Do you
have the same problem?
Thursday, February 18th, 2010 AT 7:22 PM
CJ MEDEVAC
  • EXPERT
INSURE SOLINOID IS WIRED CORRECTLY. Disconnect POS on BATT (leave NEG alone). Replace blown fuse. Remove small wire ("S") terminal from solinoid.W/ VOLTMETER set to OHMs (continuity) touch leads together meter will respond (continuity). Now touch "S" wire (not solinoid terminal) to red lead. Black lead to NEG BATT. This should NOT register on meter. If it does register you have a short (to GRD) somewhere on this wire. BEST I CAN HELP YOU WITH IT. Sorry. Love, Turddog
Friday, February 19th, 2010 AT 12:37 AM
