2003 Ford F-150 brakes and rotors
HOOPS2830
  • 2003 FORD F-150
  • V8
  • 4WD
  • 46,000 MILES
I changed all four brake pads and rotors and now when I apply the brakes the pedal pulsates and the truck shakes really bad. What would cause this and what do I need to do?
Do you
have the same problem?
Friday, July 17th, 2009 AT 4:14 PM
BLUELIGHTNIN6
  • EXPERT
One of the rotors is warped or not installed correctly, did you use resurfaced rotors or new ones?
Friday, July 17th, 2009 AT 4:24 PM
HOOPS2830
I used new ones and how do I tell which one is warped?
Friday, July 17th, 2009 AT 4:33 PM
BLUELIGHTNIN6
  • EXPERT
Does it pull either direction when you brake?
Friday, July 17th, 2009 AT 4:34 PM
HOOPS2830
No it doesn't pull, just shakes.
Friday, July 17th, 2009 AT 4:37 PM
BLUELIGHTNIN6
  • EXPERT
Definitely suspect a warped rotor then. When you apply the brakes, the brake pad comes in against the rotor and as it rotates, it should stay flat against the rotor, yours must be warped and as the high and low spots rotate by the brake pads, this pulses the pedal which you feel also causing vibrations. You may want to take your rotors back for an exchange where you bought them.
Friday, July 17th, 2009 AT 4:41 PM
HOOPS2830
Ok thanks for the help
Friday, July 17th, 2009 AT 4:44 PM
Recommended Guides
