2003 Ford F-150 AC not working properly
CALD1979
  • 2003 FORD F-150
  • V8
  • 72,000 MILES
The original battery to my truck just died and I had to replace it. Afterwards I noticed my AC not working properly. I turned on the air and I could hear the air blowing but I could not feel the air flowing through the vents. As I was driving and the RPM's went up, the air came through the vents. But as I was driving, the air would come through and then not come through depending on how fast I was going. The faster I drove, the more the air came through the vents. Heard of this before? Any suggestions? Freon maybe?
Do you
have the same problem?
Monday, January 19th, 2009 AT 8:43 PM
BLUELIGHTNIN6
  • EXPERT
Hello
Thanks for the donation.
Does your heater blow out properly? If so, you are either low on freon or your a/c compressor is going out. First, fill freon to proper level. Once this is done, test operation of A/C system. If this does not fix issue, let me know and I will post how to test a/c compressor.
Thanks for using 2CarPros. Com!
Monday, January 19th, 2009 AT 10:26 PM
Recommended Guides
