2002 Ford F-150 Won't Turn Over
PANTHERCLIMB
  • 2002 FORD F-150
  • V8
  • 4WD
  • 110,000 MILES
I've changed out the battery and starter solenoid as well as verifying that the starter is good. It will turn over if I arc across the terminals at the starter solenoid but won't fire up. I also did not notice the fuel pump priming make any noise like it normally does before I start it up.
Would this be related to a relay in the fusebox? If so, which one? I'd like to know which one is the starter and which one is the fuel pump relay so I can check/ replace them.
It may be unrelated but I also don't have turn signals either - is this a related relay problem?
Thanks
PS - know where I can get a brake/turn/reverse/trailer hookup harness to replace the one I have now? It's a quick disconnect type - just looking for a new one as this one's been chewed up since the day I got it.
Do you
have the same problem?
Monday, March 17th, 2008 AT 2:51 PM
MASTER TECH DAN
You probly have a bad ing switch electicail piece
Monday, March 17th, 2008 AT 2:53 PM
Recommended Guides
