Hello
Check ring gear in the rear end
Scan the pcm check the speed on your scaner
That will help you to pin point the troble area (if the scaner doing the same the problem may be in the back if not the you got a bad cluster )
Good luck
Wednesday, October 30th, 2019 AT 5:34 PM
(Merged)
