2001 Ford F-150 Will not run
CBNGOLF
  • 2001 FORD F-150
  • V8
  • 130,000 MILES
My 2001 f-150 pick-up has stopped running. I have changed the fuel pump and fuel filter. The fuel pump is working and pumping gas but when I check the fuel pressure I have none?
Do you
have the same problem?
Friday, November 28th, 2008 AT 1:14 PM
2CEXPT
Did you check the fuel pressure with a pressure gauge or you just check the pressure port schrader valve. No pressure points back to the pump or the fuel pressure regulator is leaking won't maintain the pressure.
Friday, November 28th, 2008 AT 1:28 PM
