Will not start
CJ MEDEVAC
  • EXPERT
Fuel do anything?---Spark or no spark?--The Medic
Tuesday, December 20th, 2016 AT 10:44 AM (Merged)
SNIPER198105
Fuel does nothin, got spark! I replaced the coil and fuel pump, still nothin. Now im gettin real mad.
HUGGIEBEAR312
  • 1999 FORD F-150
  • 180,000 MILES
I have a 1999 f-150 5.4 triton v8 4x4 that won't start I have changed the starter cylinoide on the fire wall charged the battery checked to hear if the fuel pump is working it is. I think the fuel filter isn't leeting fuel pass how do I check this
CJ MEDEVAC
  • EXPERT
Roger on spark! A SMALL shot of fuel SHOULD, at minimum, Cough and Spit. I don't know what you have done, so I'mma throwin' stuff. Move distributor from one extreme to the other (and in the middle too) While attempting to crank (a shot of fuel might help, after attempting it one cycle). Let me know if you get even the slightest "Want To". If so, and you are at an extreme (CW or CCW), we might can lift the distributor up and move it a tooth so that you have more range in that direction (I can talk you thru that, tweaking the oil pump is involved). Before, you said it ran, when you went for the timing light--Describe Well, exactly how it was chugging along. Smooth, wanting to die. Extremely low RPMs. Loping. Etc?-Now that you have had ample time to forget--You and a buddy verify you have the Firing order correct and in the correct directionThe Medic
Tuesday, December 20th, 2016 AT 10:45 AM (Merged)
  • EXPERT
Is the problem that the engine will not turn or it does and won't start.
SNIPER198105
Alright doc put a screw driver in the carb to hold the butterfly open and put the pedal to the floor. She wants to start but wont, im figuring the dang things flooded. I pulled the plugs, yupp nuttin but fuel on em. Got any idea's on dryin the cylinder short of lightin a lighter at the mouth of the spark plug holes
HUGGIEBEAR312
It won't start
CJ MEDEVAC
  • EXPERT
Screwdriver down the throat is not a good thing. Holding pedal to floor is best way to suck the fuel on thru. Or let it sit. Answer about how it was running, when it was running? What about the Twisting of the distributor CW and CCW while attempting the start. I know you hate this. But Imma gonna ask you to get a "SPIT"--#1 spark plug hole--Rotate the engine, by hand--Clockwise, as viewed from the front, till your timing mark lines up on Zero (TDC), this should occur in less than 1/2 a crankshaft rotationThen I want you to trace down #1 wire to its position on the tower of the distributor cap---Make a mark, center of #1's tower, BUT Make the Mark on the Distributor Body, below that towerRemove the Distributor Cap. IS THE ROTOR BUTTON TIP CENTERED ON THAT MARK? I KNOW YOU HAVE BEEN SCREWING WITH THIS--AND IT AIN'T MAKING SENSE.I KNOW HOW IT IS TO TUNE OUT OTHER STUFF IN YOUR MIND, AND BE DEAD SET ON SOMETHING---I REALLY WANT TO READ YOUR "SMILE" AND HEAR, "IT'S ALIVE". SO HUMOR ME, PRINT THAT OFF, DO IT STEP BY STEP (NOT BY MEMORY)---GIVE ME RESULTS. THANK YOU!---THE MEDIC
SNIPER198105
Alright doc gimmee a bit and hopefully we got it.
SNIPER198105
No spark, well doc I cant take it ima sell onea my guns and get it fixed from someone else.
CJ MEDEVAC
  • EXPERT
NO SPARK, TEST POS SIDE OF COIL FOR VOLTAGE, WITH KEY ON. WHILE YOU KNOW THERE IS NO SPARK---LET ME KNOW VOLTAGE/ OR EVEN IF THERE IS ANY--THE MEDIC
CJ MEDEVAC
  • EXPERT
WALK BEFORE YOU GIVE UP YOUR WEAPONS!
SNIPER198105
Alright doc I went and got an inline spark tester and a digital multi tester. And if me just now leads u to belive I have no idea how to use the multi tester, u would be right. What and where would u like the first readings.
CJ MEDEVAC
  • EXPERT
POS SIDE OF COIL (KIND DON'T MATTER IF YOU TEST NEG TOO, SINCE POS SIDE SHOULD HAVE THE MOST VOLTAGE.I HAVE PREPARED MYSELF FOR YOU. MONTHS AGO! HERE'S A PIC. SET YOUR METER ON NEXT NUMBER UP FROM 12 VOLTS DC (NORMALLY AROUND 20) BLACK LEAD ON BATTERY NEG POST--RED ON THE COIL POS. READ METER. DO NOT SET IT ON OHMS AND TEST VOLTAGE, YOU WILL BE BUYING ANOTHER METER! AND WE NEED OHMS TO DO OTHER TESTS MAYBE. ALSO 25 ELEVATED RANGER PUSH-UPS ARE IN ORDER FOR EVEN CONTEMPLATING A DISARMAGE--THE MEDIC
CJ MEDEVAC
  • EXPERT
BE ADVISED THIS IS A CJ PIC--YOURS IS SIMILAR--THE MEDIC
MWL7411
  • 2002 FORD F-150
  • V8
  • 4WD
  • 81,000 MILES
Engine Mechanical problem
2002 Ford F150 V8 Four Wheel Drive Automatic 81000 miles
I have a 2002 4.6L F150 4WD. On Hot days after driving the truck if I stop somewhere and go inside for around 30 minutes when I come back out and try to the start the truck it wont start. It will turn over just fine and seems like its starved for fuel. Then if I let the truck sit for a few hours, it will start right up like there was never a problem. It only does this on HOT days, never seems to a problem on cooler days. There is no Check Engine Light on, or anything else that alerts to some kind of problem.
BILLNEHRKORN
I seem to have the same problem with mine. Please see my post dated 4/30/09. I would like to discuss this problem and find a solution. Thanks, wnehrkorn2@comcast. Net
CJ MEDEVAC
  • EXPERT
PS--I WANT YOU TO TEST THIS, WHEN YOU HAVE NO SPARK!--THE MEDIC
You're lizzard drilling move to the next objective or take it to a private TOC, Recon T1 suggested you move on-get back within the assault area-I'll issue the warning order for you to execute the movement on my net-Any Q's transmit
SNIPER198105
Im getting.2 with the key off?
Recommended Guides
