Will not start
CJ MEDEVAC
  • EXPERT
LOOK THIS OVER...I MADE SOME PICS AT THE END
http://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
RETURN HERE WITH A BIG OLE GRIN!
YOUR TURN
THE MEDIC
Monday, April 3rd, 2017 AT 10:37 AM (Merged)
  • 2001 FORD F-150
  • 100,000 MILES
I have a 2001 ford f-150 V-8. Has a new battery. At first it would not start sometimes. It will turn over very well. Seams like no spark or fuel. Now it has gotten worse. I'm stranded at home. Can you help me. Please. Gary. Guttermac@peoplepc. Com.
Monday, April 3rd, 2017 AT 10:43 AM (Merged)
  • EXPERT
Gary,
You need to check to see if you have spark and fuel to the engine. THen we will know which circuit to focus on.
LSKBLC
  • 2001 FORD F-150
Engine Mechanical problem
2001 Ford F150 Two Wheel Drive
The key turns freely and all dash lights remain on but truck will not start or engage starter. Thought it might be the accuator or rod don't know how to get to them.
BMRFIXIT
  • EXPERT
Check steering column lock gear
and actuator rod to ignition switch
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_525.jpg
VARN4620
  • 2001 FORD F-150
  • 6 CYL
  • 4WD
Engine problem
2001 Ford F150 6 cyl Four Wheel Drive Automatic 000000 miles
Need help! Wife with husband over seas. Tring to keep his truck working. It ran out of gas, refilled it then started the truck it ran 10-20 minutes and shut off. I tried jump starting it because it had been sitting a little while. It didn't start. Had the battery checked and found it to be bad. Replaced it. It started. I was relieved. It ran 10 minutes and shut off. Will not restart. What did I do wrong?
I found in the book about the computer relearn process if this is not dune would that cause it to turn off and not restart. Taking the battery to have it check to make sure it is good. Have also read something about a fuel cut off sensor or something
Not sure about mileage because battery is out of the truck.
BLACKOP555
  • EXPERT
Well, first I want to clarify if its cranking just not firing up or its not doing anythign when the key is turned?
VARN4620
When the key is turned inside lights, radio, gauges on dash all work. It cranks but it just doesn't fire.
When I put the new battery in and tried to start it it fired right up ran 10 minutes and shut off. No noises no sputtering just cut off.
Thanks for your reply.
Nancy
BLACKOP555
  • EXPERT
Well next thing you can check for is bright blue sparks at each cylinder, no spark no fire.
A quick way to check for a lack of fuel is spray starting fluid directly in the throttle body, if it fires up your not getting gas.
Post back what you find.
Recommended Guides
