2001 Ford F-150 Temperture will not reach normal
KEFARLEY
  • 2001 FORD F-150
  • V8
  • 4WD
  • 148,000 MILES
Temperture on temp gauge will not reach normal temperture.
Engine coolant levels are good. Blows some hot air from heater but doesn't get as hot as it should.
Is this the water pump going bad?
Do you
have the same problem?
Monday, January 11th, 2010 AT 9:15 PM
Replace the thermostat and then report back asap
Monday, January 11th, 2010 AT 9:43 PM
Recommended Guides
