service engine soon light?
2001 FORD F-150
JDCPAULINO73
2001 Ford F150 6 cyl Wheel Drive Type unknown Automatic 67,796 miles
i have a 2001 ford f-150. the service engine soon light went on. i turned it in for an oil change. it was done but light still on. well, we just moved here to italy and i had packed the owners manual, and cant seem to located.ive looked all over but, auto place needs it to reset the service engine light.. can you tell me how to reset it or where i can find a owners manual...help husband is deployed and i dont know what to do...thanks
Dec 16, 2007 at 8:22 AM
ROBERT1WILSON
Where is the reset button for the service engine soon light on a 2000 Ford F150?
Answer
A service engine light means you have a problem that needs repairing. If you have already checked out the problems and corrected them, disconnect the negative cable from your battery for 1 minute. If the light comes back on after reconnecting the battery, you still have an unresolved engine problem.
This guide will help.
This video will show how to clear the codes.
https://youtu.be/ahK_eucFi-k
additional info : there is no "reset button". The trucks computer monitors various systems and if it senses a problem it turns on the light. The computer also stores codes that can be read and interpreted giving you a hint as to what the problem is. When the problem is fixed the computer should show no issues and the light will not light up. If you have a truck with a digital tripmeter/odometer on the dash you can access all the engine codes by pushing the reset button while you start the engine. After the engine starts continue pushing the reset button to display things such as a digital tachometer, water temp etc etc. This is there because the computer is generic to all trucks but not all trucks have the fancy option package of showing this info on a separate screen. What you are seeing is what the dealer would see with his diagnostic computer. It is all alpha numeric and makes no sense but you can find explanations to all this on several websites dealing specifically with ford trucks. Its out there on the web, you just have to dig. Good luck.
Copied and pasted from website. I think it was wikipedia. Anways I have the same problem with my truck and have not tried this yet. From this response I believe there isn't a reset button for a oil change but it is for diagnostic purposes.
Rob
Jan 16, 2008 at 12:10 PM
ROYLYN
Engine Mechanical problem
2001 Ford F150 Four Wheel Drive Automatic
My 2001 F150 has 125, miles and has had few problems. I live in Alaska where it gets cold. Recently my oil light came on and did this on & off along with the Service Engine light. I had the oil changed about 1000 miles ago. I checked the oil and it was full. I took the truck in to the shop where the oil was changed and they said they got a code for a thermometer so they installed a new one. They could not get the oil light to appear. I picked up the truck and 2 days later both lights reappeared. At first I thought it was only when the temp outside was below 10 degrees but now it seems to do it intermittently. The truck seems to run fine.
Jul 28, 2020 at 2:10 PM (Merged)
RACEFAN966
  • CAR REPAIR CONTRIBUTOR
  • 5,029 POSTS
Ok if you would call around to your local parts stores and see if one will do a free scan. Get it scanned and write the codes down. Then have the codes cleared and get back to me with what codes are there.
JKKNOTT670
I had a "service engine soon" light on my truck, took it down to Autozone and got the code (don't recall). It was for engine tempature and said I needed to 1) check coolant 2) check thermostat 3) ECT valve. - Coolant was good, changed the thermostat, drove about 50 miles and now the light is out. - Question can I go and get my truck inspected and pass the emissions test. Does the light going out mean it is good to go or is the fault still in the computer and will register and fail my emission test at inspection.
What was the exact code no.? -Check and test the engne coolant temperature sensor-start here
JKKNOTT670
it was code 125, I changed the thermostat and the light went out after 50 miles or so. My question was now that the light is out will the truck pass the emissions test on inspection. OR is the fault still in the computer and will register and fail my emission test at inspection.
If its not coming back go for it
VENTENN
My "service engine soon" came on tonight. Plugs are replaced @100,000.
The funny thing that last night someone stole gas out of the truck..wife drove enough to get more gas.
what should I been looking for?
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:f6e47ccac5="ventenn"]Engine Mechanical problem
2001 Ford F150 V8 Two Wheel Drive Automatic 120000 miles
what should I been looking for?[/quote:f6e47ccac5]
First, take it by your local parts store and have them pull codes. Post them here in forum.
Was the Gas Cap damaged? If so replace it, it will cause an emission code to set.
GINNYG
the check engine light came on whenever I drove the truck. I saw online that if I disconnected the battery the light would go off. That worked, but now the battery is reconnected and the truck won't start, it turns over but won't start.
What to do??
  • 31,937 POSTS
Hi there, first re check that the battery terminal is tight and clean, and you will have to get a scan to check the ECU for fault codes, also check main ECU fuses.
Mark (mhpautos)
WAVRIDER141
what about leaks at the intake are there common problems with upper or lower gaskets leaking is it possible that i still need to replace the maf sensor
DOCFIXIT
  • 18,828 POSTS
Maf would cause running problems are there any?
Any intake leak will cause code ie. PCV,EGR,DIP Stick
Would have to be minor leak or poor idle condition is there?
OCEANBRANCH
What is the fuel pressure? And whats it suppost to be?
JAVIER GARCIA
I CANNOT PASS INSPECTION WITH THIS
Jul 28, 2020 at 2:11 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You will need a diagnostic scan tool to read the engine codes, fix the issue then delete the engine codes.. You can purchase a scan tool or you can have a shop or part store do it for you.
Thanks for using 2CarPros.com!
HD
Last year had to smog my truck. The engine light was on. I was told that if I diconnected the battery, that engine light would go off.It did!!! I took the truck in to be smog and it passed. 2 days later the engine light came back on. Is it because of the high mileage that caused it to come on again. 2 year peivious to this sitution. I drove my truck 2 year with the engine light on. So what gives on this engine light on?
  • 31,937 POSTS
Hi there,
The light is an indication that a fault code has been stored in the ECU, you will need to get a scan done to read the code as this will be an indication as to where the problem is.
mark (mhpautos)
MERLIN2021
  • 17,250 POSTS
Yep! Pull the egr off, clean the port under it all the way to the throttle plate, I use a length of steel coathanger...put it all back together, reset the codes, if light comes on again, replace the EGR position sensor, thats the one the two small hoses from the exhaust plug into!
WRENCHTECH
  • 20,761 POSTS
What is the exact code number being set?
HMAC300
  • 48,601 POSTS
this can be an injector, fuel filter , low fuel pressure or a vacuum leak besides all other ignition problems. so you have to check for vacuum leak as well as low fuel pressure first.
ERNEST CLARK
  • 1,730 POSTS
did you replace the wires along with the coil. Also, check the connectors/wires going to the coil pack for looseness/corrosion.
DOCFIXIT
  • 18,828 POSTS
Has wiring to coil and voltage been checked? spark from coil? what is code in P0xxx format?
JNOWARK
I have a 2001 F150 SuperCrew. My problem is it runs OK under light acceleration or heavy acceleration, but just normal acceleration and it hesitates and virbates . When it does that I let up or push down more on the pedal and it goes away . no check engine light is on . I have replaced the tps and the fuel filter no change . any ideas ??
  • 110,190 POSTS
When was the last tune up? Also, have you checked fuel pump pressure?
JNOWARK
not really forsure when the last tune up was we just bought the truck a couple months ago . it started acting like this the first night we had it ran a fuel cleaner through it and it straightened out for a while now it is doing it again .
  • 110,190 POSTS
If the check engine light hasn't come on, I would start by removing a couple plugs just to check the condition. Also, check for vacuum leaks and make sure the egr isn't plugged. If the check engine light is on, let me know.
F150DRIVER
a few days ago I had this check engine light turns on all of a sudden a stays up to now.I noticed the engine performance significantly changed.and the engine rattles a little bit on idle.what could be the trouble.thanks
Sep 9, 2020 at 6:19 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
You need the codes to procede. Find and post them.
235 miles?
DADS68
Tha service engine light is on. I had a friend find the code for me and it said #1 bank lean. he told me to change the o2 sensor. Which I did. The light came back on after a few days. Is there something else I need to change also.
Thanks Ed
FLEXY5
  • 512 POSTS
You actually didn't need to change the O2 sensor for this code. This code is typically set due to either a lack of fuel or the presence of too much air. The O2 sensor is doing what it is designed to do by telling the computer that the mixture isn't correct. Check for an intake leak. You may be able to hear the hissing noise while the engine is running. Or you can spray a carb cleaner around the intake surface. If the engine changes, pinpoint where and that is your leaks.
