2001 Ford F-150 leaking coolang
PAPAHIGG
  • 2001 FORD F-150
  • 6 CYL
  • MANUAL
  • 150,000 MILES
My f150 leaks coolant from time to time. Acts like water pump leaking after eng cools some, but water pump weep hole shows no sign of leaking. Where is coolant temp sending unit and what do I have to do to get to it? Or what else could it be
Do you
have the same problem?
Monday, May 26th, 2008 AT 9:14 AM
  • EXPERT
Hi there,
the first thing to do is have the system pressure tested hot. This will show up any external leaks. Get this done first.
Mark (mhpautos)
Monday, May 26th, 2008 AT 5:48 PM
Recommended Guides
