2001 Ford F-150 Cylinder #2 missing
SMCCAIN1
  • 2001 FORD F-150
Engine Mechanical problem
2001 Ford F150 V8 Two Wheel Drive Automatic
I have 01 f150 v8 4.6l 2wd with 68K on it. Recently its been running bad with a noticiable miss. It got an engine light the other day so I took it down to the auto parts store and he said the code read "Cylinder #2 missing" So I replaced the plug with a bosch platinum +4 which was $6. I replaced to coil which is mounted on top of the plug (cos system) and that didnt help either truck is still missing espicially once it gets warmed up. Its never died on me but came close once or twice. What is the most likely the problem I am expericening here? Thanks in advance.
Steve
Do you
have the same problem?
Saturday, November 15th, 2008 AT 4:12 PM
Check compression and injector for cylinder no.2
Saturday, November 15th, 2008 AT 4:16 PM
Recommended Guides
