2000 Ford F-150
CESAR1
  • 2000 FORD F-150
  • 6 CYL
  • MANUAL
  • 135,000 MILES
I own a ford f 150 standard. When I go to start my car it wont start unless I push start my car. I had just changede my battery thinking that may be the problem, but it wasn't. The altanator in my car is good and all the connections is fine. Also, the ignition switch is fine. So, now I am out of ideals of what it could be not making my car start.
Do you
have the same problem?
Sunday, December 27th, 2009 AT 4:11 PM
OBXAUTOMEDIC
  • EXPERT
Look under the hood for the Start Relay, it will be near the battery, just follow the Positive cable from battery...
https://www.2carpros.com/images/question_images/199380/original.jpg
Jump the 2 large terminals with KEY OFF if turns over replace it. If doesn't turn over and you hear a click then most likely your starter has failed.
Sunday, December 27th, 2009 AT 4:19 PM
Recommended Guides
