1999 Ford F-150
MACONMGYSGT1@VERIZON.NET
  • 1999 FORD F-150
Transmission problem
1999 Ford F150 6 cyl Two Wheel Drive Automatic
while drivng last week vehicle heated up and and I lost all foward gears, I could still drive in reverse. I had to have the vehicle towed. A day or 2 after I started it up and it seamed to be fine, but I don't trust it. What could it be.
Do you
have the same problem?
Wednesday, March 18th, 2009 AT 8:58 PM
  • EXPERT
Hi:
Overheat can be caused by many things, a bad thermostat, clogged radiator, engine timing, headgasket. Have you been consuming coolant? If not, I would start with the cheapest thing, the thermostat.
Let me know if it helps. As far as the trans, it most likely went into something like a limp mode to protect the trans. It should be fine; however, try to avoid overheat it again.
Wednesday, March 18th, 2009 AT 9:10 PM
Recommended Guides
