1999 Ford F-150 Truck studders and stalls then dies while m
DABABOYA
  • 1999 FORD F-150
  • V8
  • 150,000 MILES
Truck started doing this after filling tank with fuel, it started sputtering and stalling like fuel was stopped up, then while moving it dies. Does not do it all the time, but quiet often. I'm thinking might be fuel filter.
Do you
have the same problem?
Thursday, October 21st, 2010 AT 3:52 PM
CH112063
You can try installing a new filter, if that doesn't help you should run it for a while with a fuel pressure tester on it. Also remember a vacuum could be forming in the fuel tank from a problem with the emission controls for the raw fuel vapors, the gas cap may not be ventilating properly, it's something else to think of before scanning the system for fault codes. OK good luck.
Friday, October 22nd, 2010 AT 7:29 AM
Recommended Guides
