1999 Ford E-150 Shakes When Braking
MMTHORN
  • 1999 FORD F-150
I have a 1999 Ford E-150 Van with the 5.4l V8 engine. The Van has about 120k miles. I have recently replaced front pads, calipers, rotors but when braking the front end shakes wildly. There is a pulsating that I feel through the steering wheel. My Ford dealer says I need all new pads, calipers, rotors but I have just replaced them. It seems as if the Steering box is a little loose and there is steering fluid coming from the seals. I am not really sure why a loose steering box would cause such shaking considering that if brakes are applied evenly there should be even pressure on both sides of the steering link. Any thoughts?
Do you
have the same problem?
Wednesday, May 23rd, 2007 AT 8:52 PM
SERVICE WRITER
  • EXPERT
HAve the rotors warrantied.
Wednesday, May 23rd, 2007 AT 9:09 PM
Recommended Guides
